an electrical gremlin
uk kev
#1 PostAuthor: uk kev » Wed Aug 29, 2007 6:23 pm
I seem to have picked up a gremlin following my ride out on Sunday.
The problem is I have lost my brake lights and the idiot light on the console keeps flashing every 2 seconds when the ignition is turned on, both with and without the motor running.
Now I at first thought it was the front brake switch, as the problem dissapeared when I dissconnected the two wires, so I bought a new switch and fitted it today, but the problem is still there.
I have checked the stop lamp bulb and that seems fine.
I have dissconnected the front switch. same problem.
I have dissconnected the rear switch. same problem.
what else can I try?
DogsbolloxofZ1B
#2 PostAuthor: DogsbolloxofZ1B » Wed Aug 29, 2007 9:57 pm
I assume you refer to the brake failure lamp in the Tacho that's flashing?
This, from memory, senses the rear taillamp is functioning correctly or is in circuit, triggered by the rear brake pedal & front brake lever. If the taillamp lamp is comming on when the brakes are applied & your failure lamp is still flashing then is likely to be an earth problem. The sensing relay, bolted by coil 1&4, uses a common earth to compare voltage levels so verify its earth connection.
My 2 cents :!:
uk kev
#3 PostAuthor: uk kev » Thu Aug 30, 2007 4:50 pm
Thank you for the reply, I have now solved the problem....
I had a good look through the official workshop manual today, and it shows that the Z1000A2 has a brake failure circuit wired in to the brake system, and this flashes a light on the console to show you have a problem. and it works, as my problem turned out to be that age old favourite, a badly fitted crimp connector, that had been crimped on to the outer sheath and not the inner wire, so causing a bad contact, that had finaly failed. so the wire was stripped back and properly crimped, and we are back in service again, I will now check the other crimps in the back light area at the weekend.
Get out you damn Gremlin, and stay out! :roll:
#4 PostAuthor: Pigford » Thu Aug 30, 2007 6:29 pm
Cool Avatar mate :wink:
May meet up with you next Friday, gonna wrangle being in the area late morning :wink:
What time you gonna be there :?: (as well as 'boot sale' Sunday)
Me mobile is: 07970 958411
uk kev
#5 PostAuthor: uk kev » Thu Aug 30, 2007 8:28 pm
I will be down for when the gates open, and be there all day, you know it's a camera thing :? lots of pictures to take.
Give me a call if you make it, and I will buy you a coffee.
07771 667 631
Users browsing this forum: Bing [Bot] and 41 guests
