reducing repaired thread
weaver
#1 PostAuthor: weaver » Wed Mar 27, 2013 4:39 pm
are there inserts available to put a 6mm thread that has been drilled and tapped to 8mm back to 6mm?
thanks
#2 PostAuthor: z1bman » Wed Mar 27, 2013 6:17 pm
#3 PostAuthor: chrisu » Wed Mar 27, 2013 6:25 pm
i like those.
weaver
#4 PostAuthor: weaver » Wed Mar 27, 2013 6:38 pm
nice one cheers :wink:
garyd
#5 PostAuthor: garyd » Wed Mar 27, 2013 7:09 pm
Neat.
I've bookmarked that page for future use :roll:
#6 PostAuthor: kev edwards » Wed Mar 27, 2013 8:37 pm
Had a large assortment of those, which i got from a german company that was installing a plating line for the company i worked for, they are brilliant inserts and a few went in my old nail when i had it, i'm down to my last few now.
KeithZ1R
#7 PostAuthor: KeithZ1R » Wed Mar 27, 2013 9:46 pm
we like them ! :D
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
martinz1000r
#8 PostAuthor: martinz1000r » Thu Mar 28, 2013 11:46 am
Very timely post. All the threads for the cam caps in the head of my GPz are fooked. A couple previously repaired with helicoils but they pulled out with the bolts.
Will these work for this application? Was looking at Timeserts but my local engineering shop doesnt do them.
#9 PostAuthor: z1bman » Thu Mar 28, 2013 11:58 am
i don't think they would be suitable for repairing the cam cap threads as you need to drill a 9.5 mm hole + the cam bearings are too close to the thread. there is not enough material there without the insert coming into contact with the seating surface of the cam bearing
#10 PostAuthor: kev edwards » Thu Mar 28, 2013 12:04 pm
martinz1000r wrote:Very timely post. All the threads for the cam caps in the head of my GPz are fooked. A couple previously repaired with helicoils but they pulled out with the bolts.
these may work on the holes with no dowels, when i had the same problem i made up a set of studs that allowed me to keep the dowels in their original positions, i also made up a combined insert with a dowel on them for mr puffin on here, the details are in previous post's, took a while to make the studs but my old bike is still running and out there 7 years later.
