electrical connection
alinus65
#1 PostAuthor: alinus65 » Sun Mar 31, 2013 6:48 pm
Hi,
sorry for my silly question but this is my first project...
where should I fix the three earth connectors shown in the image.
On the right is the cable running from the (-) of the battery.
One the other is from the green connector.
thanks
#2 PostAuthor: z1bman » Sun Mar 31, 2013 9:12 pm
the earth lead from the battery bolts on to the rear of the engine on the r/h side below the crankcase bolt. there is a 6mm threaded hole in the casing. if you have an earth wire from the regulator which is fitted under the battery case this wire goes to the negative side of the battery. not sure what your other earth lead is? it could be from the rectifier ? if so make sure it is earthed to the frame
alinus65
#3 PostAuthor: alinus65 » Mon Apr 01, 2013 8:40 am
Thank you Chief.
Everything seems to be fine.
Ciao
