Floor paint
oldtimer
Floor paint
#1 PostAuthor: oldtimer » Sat Apr 06, 2013 9:51 am
As this is the Bottom Shed section, I have just had my new concrete shed built and want to paint the floor, searching on google says that fresh concrete needs about 8 months to cure / dry out before painting, surely there is something which could be used now as commercial premises have there floors painted relatively early on or is that just resin coating.
Any suggestions so I can get it finished so I can get my bike in?
Z1parR
#2 PostAuthor: Z1parR » Sat Apr 06, 2013 10:09 am
Leave the concrete for a month and then use a concrete sealer on it , it will take a month to cure in this weather :roll:
You can use floor paint then the following day .
0172 . Geoff Parr
jimmock
#3 PostAuthor: jimmock » Sat Apr 06, 2013 11:21 am
Why don't you build a "quickie" shed.
Move into the new quickie shed to work.
After a month or so you can paint your original "un used" floor.
Then when you've moved into your original shed, you can simply demolish the quickie shed.
SIMPLE !!!!
Jimmock. :wnkr
I hate people I don't like !
#4 PostAuthor: Pigford » Sat Apr 06, 2013 3:52 pm
All related to humidity & temp. Rule of thumb is 1mm/day - so if your floor is 150mm, then 150 days :shock:
BUT: once its warmed up a bit for a week or so (night temps over 5 deg C) whack it on.
A surface sealer is OK, but check with manufacturers for instructions & compatibility :!:
Piggy (Concrete Technologist) :wink:
baz
#5 PostAuthor: baz » Sat Apr 06, 2013 5:48 pm
go on ebay and put in resin floor paint, it really is the bollocks, just like normal floor paint but you mix an hardner to it, once you've added the hardner you have about 4 hours to put it down, after that its solid. lasts 10 times longer than normal floor paint :D
oldtimer
#6 PostAuthor: oldtimer » Sat Apr 06, 2013 6:55 pm
baz wrote:go on ebay and put in resin floor paint, it really is the bollocks, just like normal floor paint but you mix an hardner to it, once you've added the hardner you have about 4 hours to put it down, after that its solid. lasts 10 times longer than normal floor paint :D
Thanks Baz, just found some, can it be applied to fresh concrete do you know? (10 days old)
marlin
#7 PostAuthor: marlin » Sat Apr 06, 2013 7:53 pm
to old timer , don't do your floor just yet let it settle dry out , paint it too quick and you are going to cause problem's later on , i work for a company that does modular building systems . and we get so much rework by the client not letting the floors dry out . GET IN PAINT THIS , PAINT THAT , COVER WITH CARPET ETC , you wouldn't rush bike work !!!! would you ????? cheers marlin
HARRY4448
Floor paint
#8 PostAuthor: HARRY4448 » Sun Apr 07, 2013 8:37 am
I've had a painted garage floor previously,but now I really want something that stands out .
Like this.
http://www.ebay.co.uk/itm/271182477407? ... 1438.l2649
nigel bessant
Re: Floor paint
#9 PostAuthor: nigel bessant » Sun Apr 07, 2013 10:20 am
HARRY4448 wrote:I've had a painted garage floor previously,but now I really want something that stands out now.
Like this.
Yes! Go for that it looks great.
jimmock
#10 PostAuthor: jimmock » Sun Apr 07, 2013 11:33 am
Looks good.
The price is for ONE tile!!
Jimmock. :wnkr
HARRY4448
Floor paint
#11 PostAuthor: HARRY4448 » Sun Apr 07, 2013 11:37 am
Works out to about £24 per square metre.
My garage floor will probably cost in the region of about £350.
But when I move I can take it with me.
floydsz1
#12 PostAuthor: floydsz1 » Sun Apr 07, 2013 12:30 pm
I put lino down on mine then a carpet i got given from my mates grandmother. nice and comfy to lay on and tools and small springs etc dont bounce of and get lost when you drop them.
Z1b,
zxr750 m2,
zrx1200
Z1000j lawson race bike,
Versys 1000gt (2019),
jimmock
#13 PostAuthor: jimmock » Sun Apr 07, 2013 12:32 pm
floydsz1 wrote:I put lino down on mine then a carpet i got given from my mates grandmother. nice and comfy to lay on and tools and small springs etc dont bounce of and get lost when you drop them.
I've got a pishy, stained, stinking mattress on my floor!!!
Jimmock. :wnkr
j.wilson
#14 PostAuthor: j.wilson » Sun Apr 07, 2013 4:28 pm
I went for bathroom flooring ...click-fit type wood (not real) flooring.
I experimented with vinyl tiles but they were not easy to replace individually if they knackered- plus they dont like fuel or heat.
I used to use carpet, but now I use my shed for woodwork too so the wood shavings were too difficult to sweep up on carpet.
After about 2 years I'm still ok about them. No real complaints.
z650/1400 bonneville hybrid.
zedi knight
#15 PostAuthor: zedi knight » Sun Apr 21, 2013 7:47 am
Hi Oldtimer.
I would go for a DPM (damp proof membrane),
its a 2 part mix and the same as resin paint.
far better than any paint, and it dries like glass.
take it from a floorlayer, this is the stuff we use on new build
concrete floors.
not cheap at out £100 a tub though.
Return to “The Bottom Shed”
