Weeping carbs
- DogsbolloxofZ1B
Just rebuilt some carbs for a mate, set the float heights & all that but on several overnight soak tests there is evidence of fuel on the carb bowls.I've replaced the gaskets too. Anybody come across a fuel resistant sealant that remains flexible?
I've sent Loctite a request for info as they have a huge range of products.
If float heights are the right then fuel level should be below top of bowl joint, so shouldn't leak. The leak is probably due to fuel leaking past float needles. The bowl gaskets need to be nice & clean, no bits of ****e on em, both sides or they will leak. Fuel tap may be weeping. Was bike on side stand or main?
- DogsbolloxofZ1B
All carb float heights set-up using Kawasaki tool as they should be and every possible surface is clean with new gaskets. I left a head of fuel in the line to each bank simulating the tank and left over night and still have evidence of fuel on the bowl joint... Can't quiet figure how this comes about unless as you say the needle valve is letting by over time, come to think of it it must be as the head of fuel had dropped.
This might not be the best way, but I usually turn the tap off a few hundred yards before I get home so as to run the fuel down a bit, to ensure it don't drip. The missus goes mad if the house smells of petrol! Or just leave idling with tap off until she starts to splutter, the bike, not the missus!!!!
- steve bowdler
- steve bowdler
I've had this problem nearly every time i've fitted a new set of float bowl gaskets(especially with pattern gaskets) or recommissioned a set of dry carbs. Seems the dry gaskets act as a wick, soaking up the fuel and weeping it out to the outside. Eventually the gaskets seem to seal themselves after a few days or weeks and the leaking stops.
The main reason is I'm a tight wad..... would cry if I saw wasted petrol on the garage floor.... If anyone does the "turn fuel off on way home lark..." don't cane it, or the weakened mixture may damage engine, in extreme cases. Had to say that, to avoid potential leagal action, in this suing culture, day and age!
I have used Loctite black silicone sealant, don't have the number with me but can check ,it's high temp and oil resistant, doesn't say anything about petrol but I used it couple of times on different carbs and it works fine, I got a set of pattern gaskets once and they were crap,leaking all round on the move, possibly they would seal after a while but I didn't fancy to ride with leaking carbs + all that smell in the garage, got rid of these , put back the old ones with a very thin film of silicone on both sides , left overnight and problem gone. If it leaks when parked it's the float valves
