z1a carbs
ogre
z1a carbs
#1 PostAuthor: ogre » Tue Apr 09, 2013 12:13 pm
anyone got a set of z1a carbs pretty please
thanks ogre
#2 PostAuthor: ADRIAN H » Tue Apr 09, 2013 3:37 pm
Sorry I have nt got any.
Creeping wont help, rarer than hens teeth. Having said this, some one will offer you some for sure. :)
A1John
#3 PostAuthor: A1John » Tue Apr 09, 2013 5:37 pm
Are you looking for early z1a carbs or the later z1b style?
Keefleaf
#4 PostAuthor: Keefleaf » Tue Apr 09, 2013 6:09 pm
Wouldn't mind seeing some pictures.
I've got a couple of sets and not exactly sure .
#5 PostAuthor: ADRIAN H » Tue Apr 09, 2013 6:54 pm
Z1 Enterrises carb guide, click on pictures and they enlarge, hope it helps.
http://www.z1enterprises.com/Z1CarbGuide.aspx
ogre
#6 PostAuthor: ogre » Tue Apr 09, 2013 7:57 pm
early z1a carbs feb 74 havin said that this probably isn't that early lookin at the guide my engine number starts 38 so it will be with the small drain screw
Z903
#7 PostAuthor: Z903 » Tue Apr 09, 2013 10:42 pm
Wired George has good info on his site as well regarding these:
http://www.wgcarbs.com//index.php?option=com_content&task=view&id=Itemid=92
Tonka
#8 PostAuthor: Tonka » Tue Apr 09, 2013 11:04 pm
I've got a spare set and confident that they are Z1A
Away until Sunday though so can't check them until then.
jimmock
#9 PostAuthor: jimmock » Wed Apr 10, 2013 12:19 pm
I've got THREE sets.
Unfortunately for you, but very fortunately for me, they are on three of my Z1A's !!!!
Jimmock. :wnkr
I hate people I don't like !
jimmock
#10 PostAuthor: jimmock » Wed Apr 10, 2013 12:24 pm
ADRIAN H wrote:Z1 Enterrises carb guide, click on pictures and they enlarge, hope it helps.
An excellent piece of info.
Jimmock. :wnkr
z1000puddin
#11 PostAuthor: z1000puddin » Wed Apr 10, 2013 7:08 pm
1975 28mm CARBS
1974 28mm CARBS
Zed til Dead
ogre
#12 PostAuthor: ogre » Wed Apr 10, 2013 9:05 pm
cheers tonka if you will and thanks for your input jimmock you greedy b*****d only joking but i could feel a poem coming on :lol:
Tonka
#13 PostAuthor: Tonka » Sat Apr 20, 2013 12:49 pm
ogre wrote:cheers tonka if you will and thanks for your input jimmock you greedy b*****d only joking but i could feel a poem coming on :lol:
Hi, just sent you a PM but if you have an engine starting with 38... they should have the later 28mm Mikuni carbs with the small drain screw angled to the side of the float bowl and not the 17mm drain plug. These are the carbs I have.
Gez has seen these and he thought they have not done many miles but they def need a ultrasonic clean (Arizona dust in them as this is where they came from when I bought them off ebay). The carbs tops will also need a a good polish. The yellow paint is still on them and they have never been adjusted by the looks of things.
malmojoe
#14 PostAuthor: malmojoe » Sat Apr 20, 2013 8:17 pm
I have read carbs had lots of small changes (if you read the wired George article) and not necessarily z1/z1a/z1b, but if you want to find out the manufacture dat it's stamped on the back stub - very small month and year.
