Just got an RD400C..... its got Newtronics (Pirhana) ignition... Tried to set timing by manual to 2.3mm BTDC, and she run good til 4/5000rpm, then power dropped off.. to retarded. Re-set to as was.. about 5/6mm BTDC and OK. Now the RD400 is supposed to be 2.3mm, and double checked dial gauge settings... spot on! What am i doing wrong???
2 strokes don't have advance curves do they???? Worried she may hole a piston, or 2!!!:confused:
Ignition timing... RD400.. by dial gauge - I know its not a blinkin' ZED... but...
Users browsing this forum: Bing [Bot] and 80 guests
