z 650 carbs
z 650 carbs
Been out on the B1 today done about 80/90 miles its been fluffing and missing at low revs I have had the carbs off half a dozen times ultra cleaned. the last time it's doing my head in now what to do next try changeing carbs? dyno kit? you would think the pilots were blocked but the carbs are spotless the only other thing is that its a bit of a pig to start from cold once started its on the button all day any help would be appreciated
john
john
z 650 carbs
oops !! how do i delete it?
- Ginger Bear
the 650 is a notorious cold starter.
Mine starts better on Dynas s coils and ignition.
Be sure not to touch the throttle when starting (in fact closing it against the springs helps the starter circuit pull more fuel due to increased vacuum).
If its fluffing when warm, it could be ignition as already mentioned by Z1b man
z 650 carbs
Thanks for that ginger bear.
Cheers for the input guys its had new coils, leads, plugs, points, condencers, checked gaps and comp's no air leaks all good don't want to give up on the old girl might try to get hold of another set of carbs just to see
z 650 carbs
Thanks Bman the ignition info is a new one on me I wont forget it !!
charlie I have a std. air box and std. zorst but I am going to run a nice little Marving 4into1 while I tidy up the std one what size jets do you reckon for the Marving??
There are no set rules.
I fitted a V&H 4-1 with the standard airbox and genuine air filter and ended up using #17.5 pilots (1 size up from std) and #107.5 mains (2 sizes up from standard). I am currently running a Predator 4-1 and the same settings work OK on that too.
All bikes are different though. I ended up where I did through trial and error. Initially I had a fluff on the first 1/8th throttle - altering the pilots cured that, then it misfired and ran out of steam at 3/4 throttle. Going up one main jet size sorted some of that - but it took 2 jumps to get it right. As you will know, getting the carbs on and off (particularly back ON) can be a pain in the arse too....I found using a hair dryer on the inlet/airbox rubbers to soften them up temporarily made the job a LOT easier ;) I was very surprised that just an exhaust change, warranted those jet changes - the manufacturers usually say no jetting upgrade is needed....but it most certainly was on mine.
I run Dyna coils and ignition too - much better than stock ...
z 650 carbs
yeah cheers Charlie will go for jetting I see there is a dyno kit available £62 wonder if that might be the way to go?
