Clutch Switch
steve bowdler
Clutch Switch
#1 PostAuthor: steve bowdler » Mon Apr 15, 2013 6:28 pm
Can someone please tell me how the clutch starter switch is secured in the clutch housing ? is it just bonded ?
#2 PostAuthor: z1bman » Mon Apr 15, 2013 6:37 pm
they have a plastic barb on them which springs out slightly when the switch is pushed into the clutch lever mounting. quite common for the plastic to go brittle + the barb to beak of + loses its tension to hold into the mounting
steve bowdler
#3 PostAuthor: steve bowdler » Mon Apr 15, 2013 7:23 pm
So bond it in then !! :x
#4 PostAuthor: z1bman » Mon Apr 15, 2013 7:27 pm
if the plastic barbs / prongs have not broken of just warm the switch with a heat gun or hair dryer + gently prise the barbs / prongs out a little bit with a small screwdriver .you can see the barbs/ prongs just below the plunger on this photo
steve bowdler
#5 PostAuthor: steve bowdler » Mon Apr 15, 2013 7:54 pm
No barbs on mine :( and there was a new one on ebay the other day bugger :evil:
#6 PostAuthor: z1bman » Mon Apr 15, 2013 8:08 pm
steve bowdler
#7 PostAuthor: steve bowdler » Tue Apr 16, 2013 6:56 pm
Many thanks , been ordered :D
