A4 silencer problem
A4 silencer problem
Hello, I have just obtained a used carb silencer for an A4 item 15 on the diagram. The problem is that the packing material is shot and resembles biscuit crumbs. Does anybody know if there is a modern material you can use to repack? Also I need the clip and screw 14,16 to secure it to the airbox which is NLA any ideas?
1972 Z1 Euro Spec
1975 Z1B UK Bike
1972 Z1 Euro Spec
1975 Z1B UK Bike
silencer
go to any motorcycle chop and buy a sheet of airfilter foam they are about 1ft square cheap as you like and use that it can then be washed periodically and reoiled
73 z1 green
73 z1 brown
74 z1a brown
75 z1b red
75 z1b blue
76 z900 green
77 z1000 black
Zrx1200r
73 z1 brown
74 z1a brown
75 z1b red
75 z1b blue
76 z900 green
77 z1000 black
Zrx1200r
