Z1000 ST CARB SETTINGS
- london calling
- london calling
- london calling
- london calling
- london calling
yup.
main jets are a different size but the rest is the same.
measurement is from top of float to surface face of the carb body.
I made up a tool similar to the special kawasaki one where you measure using a clear tube against the carb body. It screws into the bottom the bowl where the drain plug is.
