Quick one. I need a circlip plier suitable for the circlip at the master cylinder (z900a4). I have a pair of pliers with interchangeable heads but these don't fit. Not long or narrow enough.
Anyone suggest the type/make/model I need.
Circlip Pliers
Circlip Pliers
Big Bol
Z900, ZRX1200r & a Z900rs Cafe
I use a set of these,work well with long thin tips
http://www.ebay.co.uk/itm/FACOM-Outside ... 0962659935
PUM 451
Thanks for the pic Z1bman, looks sturdy enough to do the job.
The trouble is usually getting around the end of the piston bobbin to engage in the circlip holes. I believe it is one of the hardest circlips to undo!
Did this pair of circlip pliers have a spring where the two holes are?
The one I saw in the workshop manual had two pivot points , a little like a pantograph tool. I'll see if I can scan a pic of it.
RegardZ.
RegardZ.
The Laser ones are good, I picked up mine from a boot sale.
http://www.lasertools.co.uk/item.aspx?cat=0&item=4206
