GPZ1100, Z1100R Exhaust Collets Wanted
Magnum1
#1 PostAuthor: Magnum1 » Sat Jun 15, 2013 7:46 pm
I had a set, but can't find them and it's holding up the Harris rebuild. If anyone has a set to sell I would really appreciate it.
Cheers,
Rod
Never heard of a Harris Magnum
steve.w
#2 PostAuthor: steve.w » Mon Jun 17, 2013 6:39 pm
big green buses mate makes em in stainless think theyre abot £30 for a set of 8 :idea:
Magnum1
#3 PostAuthor: Magnum1 » Mon Jun 17, 2013 10:35 pm
[quote="steve.w"]big green buses mate makes em in stainless think theyre abot £30 for a set of 8 :idea:[/quote
Cheers Steve, have you got a link?
big green bus
#4 PostAuthor: big green bus » Wed Jun 19, 2013 6:35 pm
I will ask him if he can make some.
big green bus
#5 PostAuthor: big green bus » Wed Jun 19, 2013 6:38 pm
Have you or can you get hold of one to measure as there are a few different lengths
#6 PostAuthor: Al » Thu Jun 20, 2013 5:17 pm
I have one of the standard ones i can measure but this may not help.
Magnum1
#7 PostAuthor: Magnum1 » Fri Jun 21, 2013 6:56 am
big green bus wrote:Have you or can you get hold of one to measure as there are a few different lengths
Thanks for responding Steve - diameter is 38mm by 28mm deep.
Cheers,
Rod
big green bus
#8 PostAuthor: big green bus » Fri Jun 21, 2013 7:55 am
I have sent him a message and I will let you know as soon as I hear back. If he makes them he tends to make a few sets so I will post them on here if he does.
Magnum1
#9 PostAuthor: Magnum1 » Fri Jun 21, 2013 4:08 pm
Cheers, I looked on Z Power, but they don't list them. I'll give them a call on Monday to see if they can get them.
Cheers,
Rod
garyd
#10 PostAuthor: garyd » Fri Jun 21, 2013 5:16 pm
I'd be interested in a set....I managed to give my only set away last year...Doh!
big green bus
#11 PostAuthor: big green bus » Fri Jun 21, 2013 8:15 pm
He said £40 delivered for one set, but £30 a set if he gets six orders , he also said to measure the inside diameter of the clamp to be sure, he thinks the size is for the larger ones not the GPz/Z1000j type, Zorded could you confirm the length of your gpz ones please as he will not take them back if the measurements are wrong.
#12 PostAuthor: Al » Fri Jun 21, 2013 9:06 pm
I've got two piece ones at 38mm by 28mm deep for the J1 with J head same as Unitrak head which it has now. These are fitted to a set of Laser headers.
The Laser headers are a very tight fit in the exhaust port counter-bore!!
These are the ones with the one piece cast alloy clamp.
I also have some one piece ones from a Marshall which is a J fitment Stamped Z1000 J which are 37mm minor diameter and 30mm deep. These have a major diameter of 48mm. The Marshall headers are noticeably smaller in diameter than the Laser ones fitted at this time.
The diameter of the Marshall headers is 33mm.
These have a steel plate for a clamp rather than the above
Hope this helps.
#13 PostAuthor: z1bman » Fri Jun 21, 2013 9:43 pm
standard ones part no 92027-1300 cradley have them in stock
big green bus
#14 PostAuthor: big green bus » Sat Jun 22, 2013 7:11 am
z1bman wrote:standard ones part no 92027-1300 cradley have them in stock
Kawasaki Part Number Displayed: 920271300
Kawasaki Part Description: COLLAR,EXHAUST PIPE
Kawasaki Part UK(£) Price: £2.75
Not too expensive for the standard ones, it is up to you if you go for them or the stainless steel.
(is anybody who has had the S/S ones had any problems with them ?)
Magnum1
#15 PostAuthor: Magnum1 » Sat Jun 22, 2013 8:07 am
I might as well go for the Kawasaki ones, never bothered to phone them because I thought they would be extortionate, but 2.75 is not too bad if that's for 1 set. I'll give em a call and check.
Cheers,
Rod
