could any body help with this one
i have a 2003 Z1000 that as suddenly started to leak oil from a small hole in the bottom of what i think is the water pump/oil pump combined unit ,oil only leaks when the engine is running and seems to be like a pulse of oil that is coming from this hole .before i go and rip the thing apart has anyone got an idea if it needs a new pump or housing or if its just some sort of pressure release valve or the like that fitted inside the unit
oil leak
donkiddick
