20 Amp fuses
20 Amp fuses
#1 PostAuthor: ZedHead » Sun Jul 07, 2013 6:45 pm
Has anyone else experienced the 20 amp fuse going high resistance?
I ordered a new fuse assy from z power because the old on was melted due to high resistance fuse overheating and also causing intermittent misfire (low volts at the coils).
After fitting the new assy the bike was dead. Stuck the meter across the fuse, low and behold it reads 38 ohms!
#2 PostAuthor: Ginger Bear » Tue Jul 09, 2013 7:13 am
I've had glass fuses that look ok, but the fuse wire had detached from the end cap, so I'm not surprised you've had one with a high resistance. :shock:
#3 PostAuthor: ZedHead » Tue Jul 09, 2013 8:46 am
There was me thinking it was just me :D
Another reason to do the Wired George mod...
zman
#4 PostAuthor: zman » Tue Jul 09, 2013 9:46 am
I replaced my 20amp fuse with a 20amp mcb.The type they use for these big in car sound systems.
never had a problem since.And if you break down in the middle of nowhere,at least you won't run out of fuses looking for the problem
keep thoses wheels turning
Taffus
Re: --------
#5 PostAuthor: Taffus » Tue Jul 09, 2013 10:02 am
zman wrote:I replaced my 20amp fuse with a 20amp mcb.The type they use for these big in car sound systems.
Now that is a good idea! :D
KeithZ1R
#6 PostAuthor: KeithZ1R » Tue Jul 09, 2013 1:07 pm
+1 :D
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Hinckley
#7 PostAuthor: Hinckley » Tue Jul 09, 2013 3:39 pm
Where can we get these from?
#8 PostAuthor: ZedHead » Tue Jul 09, 2013 4:08 pm
Hinckley wrote:Where can we get these from?
http://www.ebay.co.uk/itm/12V-DC-CAR-AU ... 0697711758
#9 PostAuthor: Ginger Bear » Tue Jul 09, 2013 4:09 pm
Hinckley
#10 PostAuthor: Hinckley » Tue Jul 09, 2013 6:46 pm
Cheers guys, wish I new they existed when tackling the spaghetti!
