Z 1000 ST Front mudguard
Vendetta761
#1 PostAuthor: Vendetta761 » Tue Jul 16, 2013 7:42 am
Front mudguard of an ST required, believe a Mk2 is the same but happy to be corrected if that is not the case [everything else on the ST is .0003mm different so no reason its not this time].
If there is anything else out there that fits please let me know, I can build up extra knowledge on the ST database.... :wink:
1980 Z1000 E1- ST , 1980 Yamaha XT 250 3Y3 , 1979 Moto Guzzi G5 special , 2000 V11 special, 2009 XT660 X
Redbeard
#2 PostAuthor: Redbeard » Tue Jul 16, 2013 4:00 pm
ST has a leading front axle mate so sorry, mk2 won't fit. I found all this out when I had mine. :x
1979 Z1000ST
Vendetta761
Front Mudguard Z 1000 ST
#3 PostAuthor: Vendetta761 » Wed Jul 17, 2013 9:19 am
Thanks chief, ST mudguard only it is, still looking for one , cash and biscuits waiting.... :P
Vendetta761
#4 PostAuthor: Vendetta761 » Tue Jul 23, 2013 10:32 am
mmm, rarer than I thought.
In that case, I can modify up another mudguard with a similar radius, seem to be a lot of specials out there with trick front mudguards but a lot of them are plastic, I was under the impression the Z solid number acted as a little brace so wanted sturdy metal.
Anyone any ideas for something I can butcher, I mean modify?
freddyz1r
#5 PostAuthor: freddyz1r » Tue Jul 23, 2013 10:42 am
Depends on what you are trying to do V. But , i've had to put a chrome 1 on my z1r.
I was also told it had to be metal to act as a "brace".
You could always add a fork brace? The micron ones look good and keep popping up on here,(i've missed out on 2 :oops: )
Good luck, freddy
Yellow
#6 PostAuthor: Yellow » Tue Jul 23, 2013 7:02 pm
I have an aftermarket one, shorter then standard and painted.
Has some rust on inside. Not sure how useable it is. will get some picks up soon.
Vendetta761
#7 PostAuthor: Vendetta761 » Tue Jul 23, 2013 9:42 pm
Thanks Freddy and Yeloow, at the moment i have one bike that will be a dry run bike only if i do not get some kind of mudguard on it, i know the original is solid and strong and acts like a bit of a brace ( I too have been hunting for a micron or telefix or similar but no luck so far) :??
If you have a spare one Yellow then biscuits and beer tokens can be made available, all in a good cause you know :wink:
If I cannot sort a mudguard then for the while it will be a dry run bike which may not be a prob, could look pretty mean but I think some kind of brace must be required.
Thanks for the replies, much appreciated :lol:
Yellow
#8 PostAuthor: Yellow » Wed Jul 24, 2013 8:25 pm
Is this any good to you?
PM your address and I'll stick it in the post.
Vendetta761
#9 PostAuthor: Vendetta761 » Thu Jul 25, 2013 1:05 pm
This looks just the job, PM sent ! :lol:
