Z1000 B C ST MKII J GPZ R etc. ignition pick up parts needed
Hi Guys
I have an ignition pick up assembly that is in pieces (I don't even know if it works) and is missing one of the brown magnets sandwiched between the pick up plate and the mounting back plate.
Does anybody have a damaged set I could have the magnet off or a damaged set that nobody wants?
Thanks in advance Amigos
Gus
Gus
"Set the GRINDER on it"
- paul doran
- Ginger Bear
- z1000puddin
That looks like the badger.
Not sure how to tell if there is a difference between the Z1000 models and say 650/750 systems.
The wires on mine from the pulse coils are
Black/blue = left coil
Red/yellow = right coil
It's one of the brown half moon magnet sandwiched between the two plates that I need.
Wouldn't want to break a working system though.
Gus
Gus
- z1000puddin
