Brakes
Fred the Zed
Brakes
#1 PostAuthor: Fred the Zed » Sun Aug 11, 2013 2:43 pm
:shock:
Right, that's it! There's a definite need to upgrade the brakes on my Z1R. I've already cleaned the standard calipers up but the thing is still a deathtrap in waiting.
I'm looking for anyone who can make me / sell me a set of caliper brackets so I can fit a set of more modern Sumimotos / Nissins / Brembos / Tokicos. Failing that, has anyone got a pattern I can give to a machine shop to knock some up please?
Fred
Paid Up Member
nw66
#2 PostAuthor: nw66 » Sun Aug 11, 2013 6:21 pm
try using your feet :D
Ducati 1199R Race
Ducati 1198R Race
Suzuki GS/GSXR1216 Turbo Drag
Suzuki Katana 1170 Homa sz
Yamaha R7/R1 motor
Kawasaki ZXR750R M1
KTM SXF250
The older it gets the faster it was :-))
Jay1969
#3 PostAuthor: Jay1969 » Sun Aug 11, 2013 7:52 pm
Buzzard is really good with stuff like that...
http://z1ownersclub.co.uk/forum/viewtop ... sc&start=0
You'll see the caliper bracket as you scroll down nearer the bottom :up
Kev1R
#4 PostAuthor: Kev1R » Mon Aug 12, 2013 7:44 am
I found a significant improvement in my brakes when I changed to Hel brake lines all round last year - and the front ones were already (Venhill) braided lines.
Obviously as part of the process of changing the brake lines you also end up replacing the brake fluid and bleeding the system - this in itself can show some improvement and if you've not done this for a while I would suggest this could be a cheap and easy 1st step.
steve bowdler
#5 PostAuthor: steve bowdler » Mon Aug 12, 2013 8:46 am
Nosher903
#6 PostAuthor: Nosher903 » Mon Aug 12, 2013 3:47 pm
Baldylocks put Brembos on his Z1R -
http://www.z1ownersclub.co.uk/forum/vie ... &start=165
Z1b, GPZ900r, XJR1300
Fred the Zed
#7 PostAuthor: Fred the Zed » Fri Aug 23, 2013 4:49 pm
Hmmm
after a bit of thought and very useful communication with Baldylocks and Buzzard, I think my first effort will be to replace the the current front master cylinder contraption with something more modern (GSXR1000) and fit a simple two line connection between the new master cylinder and the old calipers. I'll see what a difference the less convoluted set up and new fluid brings. If thats still lacking in the retardation department then I'll follow Baldylocks' K100 Brembo caliper set up (and speak nicely to Buzzard about his engineering prowess).
Fred :|
Paid Up Member
KeithZ1R
#8 PostAuthor: KeithZ1R » Sun Aug 25, 2013 11:06 pm
Ride slower you will live longer :)
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
