z1r mkII St Ltd bits required. all sorted Thanks
lescr
#1 PostAuthor: lescr » Wed Aug 21, 2013 7:07 pm
Im after the following Z1r bits for a D3 that I recently purchased.
Parts I require:
R/Hand fairing end cap
R/Hand handle bar switch (kill switch, start button,lights on/off)
L/Hand handle bar switch, top part or just the hi lo selector
Parts I would like but dont need for mot:
complete Z1r air box
centre stand
18" rear wheel with cush drive
Sensible prices please guys
Les
Vendetta761
#2 PostAuthor: Vendetta761 » Wed Aug 21, 2013 7:24 pm
I have a couple of ST air boxes kicking about, 2 different types, think one was a U.S import , I will try and dig them out and are a picky to see if the are what you are after.
What goes around comes around in his club it seems so you are welcome to one or other if you cover the postage,
Cheers V
1980 Z1000 E1- ST , 1980 Yamaha XT 250 3Y3 , 1979 Moto Guzzi G5 special , 2000 V11 special, 2009 XT660 X
lescr
#3 PostAuthor: lescr » Fri Aug 23, 2013 7:09 pm
[quote="Vendetta761"]I have a couple of ST air boxes kicking about, 2 different types, think one was a U.S import , I will try and dig them out and are a picky to see if the are what you are after.
Cheers V[/quote]
Ok Thanks for that
#4 PostAuthor: paul doran » Sat Aug 24, 2013 1:16 pm
ST airboxes will not fit the MK2
lescr
#5 PostAuthor: lescr » Sat Aug 24, 2013 1:30 pm
[quote="paul doran"]ST airboxes will not fit the MK2[/quote]
My mistake for not making topic clearer The Z1r I have has a mkII engine which shares the same clutch cover and cam cover as the shaft. The air box that I am looking for is for a Z1r not mkII or shaft
Thanks for pointing this out
