Harris Magnum 2 rear sub-frame
martinz1000r
#1 PostAuthor: martinz1000r » Tue Aug 27, 2013 4:30 pm
Can anyone that has an un-molested Harris post up a few pictures of what the rear subframe and fittings should look like?
I just tried to fit the standard bodywork to mine and it dont fit. I suspect that some form of surgery has taken place to accommodate the ghastly race seat it currently sports.
Padders
#2 PostAuthor: Padders » Tue Aug 27, 2013 5:13 pm
Here are a few of my standard harris mag 2 hope they help.
PUM 13
martinz1000r
#3 PostAuthor: martinz1000r » Tue Aug 27, 2013 5:23 pm
perfect! Yes mine has been bent upwards and some new brackets welded on to give a mounting for a battery box and the new seat. Out with the angle grinder I guess!
Where does the battery go btw?
Padders
#4 PostAuthor: Padders » Tue Aug 27, 2013 5:30 pm
The battery sits in the rear of the seat unit will see if I have a picture if not will take one later tonight.
Remember to post some pictures of your bike.
PUM 13
martinz1000r
#5 PostAuthor: martinz1000r » Tue Aug 27, 2013 5:37 pm
Padders wrote:The battery sits in the rear of the seat unit will see if I have a picture if not will take one later tonight.
It's a Suzuki! I'll be barred from the forum for being disloyal...... :oops:
Padders
#6 PostAuthor: Padders » Tue Aug 27, 2013 5:43 pm
Nah we need people on the site that have varied tastes so no worries be boring if the only bikes we liked were just zeds
PUM 13
martinz1000r
#7 PostAuthor: martinz1000r » Tue Aug 27, 2013 7:20 pm
Magnum and 1100 Slabbie with my GPz....
Padders
#8 PostAuthor: Padders » Tue Aug 27, 2013 8:49 pm
Nice trio you have there Martin are you sure your frame is not a mag 1. Just asking as that was angled up higher at the back.
Here are a couple taken of the rear battery compartment. One with the cover on and one off. Let me know if you need any further information.
PUM 13
KWACKERZ1
#9 PostAuthor: KWACKERZ1 » Tue Aug 27, 2013 9:18 pm
Martin's looks like its got a mag2 tank and without looking closely at the headstock its difficult to tell Mag1 or 2.
There are some pictures of Mag one frames bare in a couple of my project threads, but Martin if you need some I could get some for you.
Jay1969
#10 PostAuthor: Jay1969 » Tue Aug 27, 2013 9:50 pm
Hiya, what is the rear suspension like with the
shock absorber positioned like that, compared to the ride on a
'conventional' ride?
HowieD
#11 PostAuthor: HowieD » Wed Aug 28, 2013 8:42 am
Mine arrived from Harris like this; two threaded Bungs in the end of the Tubes, no other bracktes welded on:
Harris supplied this battery box too but I had to butcher it to fit:
hope this helps
Regards
H
PETER KZ1A
#12 PostAuthor: PETER KZ1A » Sun Sep 22, 2013 1:08 pm
GSX11 magnum wooo what a beaut
PETER KZ1A
#13 PostAuthor: PETER KZ1A » Sun Sep 22, 2013 1:11 pm
I had a GPZ 11 mag 2 flogged it when we moved faaaaak
#14 PostAuthor: Pigford » Mon Sep 23, 2013 6:08 pm
Heres a shot of me Mk.I if any help
