AIR INTO CARB/INLET RUBBER?
jon the gripper
#1 PostAuthor: jon the gripper » Tue Oct 02, 2007 3:43 pm
my zed is hanging on at low revs? it was running fine then out of nowhere like a lump of shit,checked all rubbers found a tiny split in one so replaced it with new,reassembled and it was better,but still more like a 500 than my zed 1075,more fiddling trying to get as good as seal as poss,slightly better again,rev up to 8000,but still not crisp and as it was,is there a sealent that i can use on rubber_carb to add extra seal as i am sure this is the root of my problem and on disassemble there was a jelly like substance in rubbers,help!!
z1bnackerkwacker
#2 PostAuthor: z1bnackerkwacker » Tue Oct 02, 2007 4:12 pm
Have you had the carbs apart ?... :?:
Steve Cooke
#3 PostAuthor: Steve Cooke » Tue Oct 02, 2007 7:30 pm
If the clamps are in good order and on new rubbers you shouldn't need anything else to achieve an effective seal, also there is a good chance that some of that jelly like substance you speak of has now worked it's way into the carbs, sounds like a good clean is in order.
#4 PostAuthor: Pigford » Tue Oct 02, 2007 9:29 pm
Wot Mr Crook... errr Cooke said, and if rubbers are cracked you MUST get new ones, don't risk a holed piston :!:
jon the gripper
#5 PostAuthor: jon the gripper » Wed Oct 03, 2007 3:31 pm
HAD CARBS APART,FLOATS ALL OK,MAIN JETS UNBLOCKED,BUT WERE CLEAR ANYWAY,ALL THROTTLES FINE AND IN TANDEM,NEXT JOB IS DRAIN FUEL AND REFILL WITH NEW,HOPE ITS ROPY PETROL!
floydsz1
#6 PostAuthor: floydsz1 » Wed Oct 03, 2007 4:28 pm
petrol only last a few months, you can often tell because it smells like vinegar, dont put it on your chips though. I had a race bike a few years ago that wouldnt run right on the dyno, seem very flat, petrol was only about 3 months old, put new in it and it was perfect.
