goddam!now i've snapped a bolt in the cam holders!!
kenny z9fighter
#1 PostAuthor: kenny z9fighter » Tue Oct 02, 2007 6:29 pm
got the head on,exhaust,the very last bolt on the no 4 cam cap,snap!took the cap off,snapped down at the bottom,drilled a hole in it to try and get it out,it aint happening.helicoil?easy out?was wanting to fire it up but with 3 bolts in i guess thats being stoopid
#2 PostAuthor: Pigford » Tue Oct 02, 2007 9:26 pm
To be honest, if you're just firing her up to check rest is OK, 3 out of 4 bolts won't hurt, but you need to fix it before going out for a ride :cry:
Has it broken dead flush or down inside a bit?
kenny z9fighter
#3 PostAuthor: kenny z9fighter » Tue Oct 02, 2007 10:24 pm
it broke down rite inside but after a call to my mate crawf whos a master of anything to do with metal its fixed,drilled it out and tapped it keeping the 6mm thread,so its 1 step closer to the road :wink:
#4 PostAuthor: chrisNI » Tue Oct 02, 2007 11:37 pm
Don't torque it up to what it says in the manual - should be about five and a half foot pounds not twelve. Twelve will break them.
#5 PostAuthor: Pigford » Wed Oct 03, 2007 6:48 pm
Yeah, just nip the bastard & a drop of locktight :!:
kenny z9fighter
#6 PostAuthor: kenny z9fighter » Wed Oct 03, 2007 9:51 pm
ye thats what i done this time,think the haynes manuels gettin a new home in the toilet when i run outa ass wipe!
#7 PostAuthor: chrisNI » Thu Oct 04, 2007 9:24 pm
It's wrong in the factory manual too, thet's probably where they copied it from. And it's still wrong in the 1000J/R factory manual.
Manuals got it wrong i found to my cost also
#8 PostAuthor: Al » Sun Oct 28, 2007 11:32 am
The correct figure is calculated to be; 104 inch pounds which is equivalent to 8.666 rec. ft-lbs. 12 foot pounds will absolutely snap bolts or strip threads as well as overloading the caps. Need to use a low range torque wrench for this and preferably one with an external indicator. Looks like degrees but in inch pounds or foot pounds.
Al.
jam
#9 PostAuthor: jam » Mon Oct 29, 2007 1:22 pm
I ended up re threading every single 6mm hole in my J head, I used the Wurth Timesert kit, which although more expensive than helicoil, is far superior. Since then I've had no problems what so ever.
