1100r rear sets
1100r rear sets
any recommendations? i have raask at the moment but fancy something a bit more modern looking,also what do you do about rear foot pegs as it will fail an mot with out these because the bike has a pillion seat
- Ginger Bear
Extract from the VOSA MOT booklet, (http://www.motinfo.gov.uk/htdocs/m1s06000201.htm)
Information Method of Inspection
Pillion foot rests are not required on motor bicycles that only have a single seat. In addition some motor bicycles used on or after 14 June 1993, which are intended to carry a passenger may not be fitted with footrests but with hand holds attached to the motor bicycles frame adjacent to, or part of the seat. Refer to manufacturers information eg owners handbook.
Reason for Rejection.
(ii) a missing or insecure footrest
martinz1000r
I have KipKawa 1000S replicas on my ELR. Needed a bit of modding as design to operate on a frame with no side stand and they foul on the mounting bracket. Look good though.
Not sure what i will do for MOT as simply nowhere to fix pillion pegs anymore
martinz1000r wrote:I have KipKawa 1000S replicas on my ELR. Needed a bit of modding as design to operate on a frame with no side stand and they foul on the mounting bracket. Look good though.
Single seat unit ?
- big green bus
Re: 1100r rear sets
weaver wrote:any recommendations? i have raask at the moment but fancy something a bit more modern looking,also what do you do about rear foot pegs as it will fail an mot with out these because the bike has a pillion seat
this happened to me and I just cut the foam off the back half of an old seat for the mot looked horrible but worked ok
martinz1000r
zorded wrote:You can get cheapy footrests to temporarily bolt onto the lower shock mount for the MOT. I must get some myself.![]()
Al, can you post a link to such a thing on eBay or similar?
It was Fatty Z1R had them as rear rear sets on his drag bike. Think he said they came from some place near Guildford!!! It occurs to me that my standard J rears will do just the same as they have a bracket with a single hole in.
When it stops persisting down i will go have a look in the shed.
Users browsing this forum: No registered users and 115 guests
