i am changing my speedo over to digital on my Z900 rather than run magnetic pick up on discs is there any mod or conversion so i can run a pick off the speedo so it keeps neater looking
thanks all
electric speedo
- Ginger Bear
speedo
Ginger Bear wrote:Google Koso. (Digital speedos direct) or something like that.
I'm sure that they sell a gizmo that will screw into your speedo drive & convert it to 'pulses'.
that who speedo is off koso
was seeing if there was another way that people had used different speedo pick up and adapted it rather than using the cables and magnetic pick up
(like some people have done on gsxr they use and adapt a zx9 or bandit casing and use the sensor pick up so it sends pulse to the clocks after some thing like this)
