Z1R Fuel Tap
Tonka
Z1R Fuel Tap
#1 PostAuthor: Tonka » Sat Sep 14, 2013 2:59 pm
Need a new or working fuel tap for a Z1R as the one fitted to the bike is extremely difficult to turn on and off.
Also the filter is past it's best anyway so best to replace it
Tonka
#3 PostAuthor: Tonka » Sat Sep 14, 2013 8:21 pm
Many thanks Paul, ordered one from the 3rd choice you gave me. Cheers
DavidZ1R
#4 PostAuthor: DavidZ1R » Sun Sep 15, 2013 8:59 am
Hi Tonka, I have had the same problem on mine, posted a couple years ago, not alone either, I think its the fuel, stripped mine down, replaced the o ring seal, lubricated it and it was much better, still is but tight, no point now you have bought one. :)
#5 PostAuthor: z1bman » Sun Sep 15, 2013 12:20 pm
these type of fuel taps where very stiff to operate even from new
Gavin
#6 PostAuthor: Gavin » Sun Sep 15, 2013 12:32 pm
This is a problem on Z1300's I am going to follow this As it works and cheaper than buying a new tap
Taken from the Z1300 forum
http://www.dreadsbikersite.com/Z1300/fuel_tap.htm
Z1000 MK2
Z1300 DFI
KeithZ1R
#7 PostAuthor: KeithZ1R » Sun Sep 15, 2013 3:32 pm
Pull it apart and clean it put a bit of silicon on the "O" ring DONT lose the little spring that pushes the cone into the housing :oops:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
