Can anyone tell me why my indicators won't flash properly when the headlamp is on.....they just come on and stay on without flashing.
I have read that Z1/Z900s do not have the best electrics ever invented, but I assume I have a small fault to sort out...???
Kerrigan (Z900)
Dodgy indicators
had the same problem on my Z900, I've fitted on board voltmeter to find out what's wrong, battery voltage is between 12-12.5V, charging starts over 3000-3500 rpm and by 4500rmp voltage is a bit over 14 volts and stays roughly there to the redline, now if I stop with the headlight on voltage drops to less than 11V,add indicators and it goes down to nearly 10V, I have 60W halogen bulb fitted so with stock 45W the readings could be a fraction of a volt higher, I also replaced the indicator relay and it flashes quicker and with less "effort" now,the old one would sometimes stop flashing with the lights on and engine not running, the above might measure different on your bike (revs and volts depending on your regulator),in general these electrics were OK when new and could only get worse with the age
Thanks guys.
I think a new flasher relay is called for.
Actually my bike was sold about a year ago through RWHS and the job sheet with it says they replaced the flasher unit - maybe it was a used or faulty one.
I assume that a lot of you would have read "Dave's guide to the Z1/Z900" from Z Power.
I downloaded it yesterday.
What a great read !
Everything you always wanted to know and some things you really didn't need to know.....
I especially like Dave Marsden's comment that the Z900 is the best of the 900s and that in his opinion the green Z900 A4 is the best looking bike ever to come out of Japan.
I'm so glad I didn't save up more money and buy a Z1B !!!!!!
What a great read !
