Clutch push rod - GPz1100 Unitrak
martinz1000r
#1 PostAuthor: martinz1000r » Sat Sep 28, 2013 12:13 pm
Would anyone have a clutch push rod for said Gpz? Must be Unitrak A1-A2 or Z1300. Part number 13116-1050 (cancelled). Either that or would someone mind taking an exact measurement of length and diameter so i can get one made. Mine's bent!!
big green bus
#2 PostAuthor: big green bus » Thu Oct 03, 2013 7:53 am
I made mine out of silver steel you can get it in the right diameter just cut it to length I will measure mine for you
martinz1000r
#3 PostAuthor: martinz1000r » Thu Oct 03, 2013 8:00 am
Many thanks! Great help
big green bus
#4 PostAuthor: big green bus » Sun Oct 06, 2013 9:15 am
8mm diameter 310mm long
martinz1000r
#5 PostAuthor: martinz1000r » Sun Oct 06, 2013 10:04 am
Thanks for the help on this
big green bus
#6 PostAuthor: big green bus » Sun Oct 06, 2013 10:20 am
