Z650 Tap.
Yellow
Z650 Tap.
#1 PostAuthor: Yellow » Sun Oct 06, 2013 5:58 pm
Hi,
Does anyone know what other model has same petrol tap as Z650.
http://www.ebay.co.uk/itm/KAWASAKI-ZX9- ... 19d59b377f
Would this one match if I changed the tap part?
Holes on mine are 35mm apart.
Cheers.
Mine is the 82 CSR model. Sorry.....
#2 PostAuthor: z1bman » Sun Oct 06, 2013 6:19 pm
this one's a for a b1 model not sure of the dimensions. but only has one outlet + is not a diaphragm type
http://www.ebay.co.uk/itm/Kawasaki-Fuel ... 1143126951
Charlie
#3 PostAuthor: Charlie » Sun Oct 06, 2013 7:06 pm
If you have the later vacuum operated Z650 tap, then any of the Suzuki GS/GSX 550/750/1000/1100 vacuum taps (not the faired ESD/F models though) from the same period of time will also fit without much difficulty.
The angle of the fuel outlet is different on the GS/GSX tap but it does still fit. The hole spacing and the rubber gasket is the same.
If you have the early type Z650 carbs without the vacuum outlet take off, you can still use the same taps but you need to pick up a vaccum feed from one of the carb balancing points.
You can also fit the manual type tap from the 650 B1/C1 to vacuum outlet carbs if you cap off the outlet on the carbs. The spacing is the same on those too.
There are plenty of pattern taps about though. Dave M at Z Power sells 'em both in vacuum and manual type
:wink:
Yellow
#4 PostAuthor: Yellow » Mon Oct 07, 2013 6:42 pm
Cool.
Thanks for the help lads. :)
Users browsing this forum: Bing [Bot] and 118 guests
