Engine Mounts
Taffus
Engine Mounts
#1 PostAuthor: Taffus » Mon Oct 07, 2013 4:19 pm
Hi
Does anyone know the part number and name for the rubber mounts that fir in the front of J series engines?
Alternatively the sizes needed to make up some metal ones
#2 PostAuthor: z1bman » Mon Oct 07, 2013 4:28 pm
92075-1272 cradley have them stock £20
http://www.ebay.co.uk/itm/Genuine-OEM-K ... 5af0ab5afb
Taffus
#3 PostAuthor: Taffus » Mon Oct 07, 2013 4:39 pm
Thanks, thats a lot clearer, I was looking for something like the ones in my old kettle, theses are very different
But at those prices it's going to cost £80! according to the parts book I need 2 types
Are they worth replacing or should I go for metal replacements?
Padders
#4 PostAuthor: Padders » Mon Oct 07, 2013 4:52 pm
Hi Mark you need
2x 920751272 upper engine mounts
4x 920751274 side engine mounts
2 x 920751273 lower engine mounts
I would definitely replace with new if you have the engine out and are doing a full rebuild the difference with new ones against old worn rubbers is noticeable. You can get away without the side mounts if yours are okay.
Got all mine from Z Power next day delivery
PUM 13
Taffus
#5 PostAuthor: Taffus » Mon Oct 07, 2013 6:53 pm
Thanks Ian
Do remember roughly how much?
Padders
#6 PostAuthor: Padders » Mon Oct 07, 2013 7:30 pm
£78.46 all in but the side mounts were nearly half the price Mark
PUM 13
Taffus
#7 PostAuthor: Taffus » Mon Oct 07, 2013 7:34 pm
with the amount I have spent on this engine that's peanuts :shock:
I have been in touch with a friend who is having some solid mounts made for a J so I'm getting a set too. Anyone tried solid mounts?
#8 PostAuthor: z1bman » Mon Oct 07, 2013 7:38 pm
92075-1272 = £20.24 each
92075-1272 = £12 46 each
in stock at cradley
