wanted - early Z1 or Z1A sprocket cover
malmojoe
#1 PostAuthor: malmojoe » Thu Oct 17, 2013 7:37 pm
does anyone have one they can sell, or is there a way to convert a later one?
cheers
:roll:
kas750
#2 PostAuthor: kas750 » Thu Oct 17, 2013 7:51 pm
You can polish the gear positions off a later one.
Gus
#3 PostAuthor: Gus » Thu Oct 17, 2013 9:14 pm
What's an early cover like?
I may have one as it is different to all the others I have seen.
Anybody got a pic. or info. which may help?
Gus
"Set the GRINDER on it"
malmojoe
#4 PostAuthor: malmojoe » Thu Oct 17, 2013 9:22 pm
it doesn't have any gear numbers on it.
http://s1223.photobucket.com/user/malmojoe/media/1973%20Kawasaki%20Z1/P1020555_zpsa2d9db2b.jpg.html?sort=6&o=0
Kas - I've thought about that, but they're embossed pretty deep, I think there is another type with the raised numbers - that would be handy too.
AL MARSHALL
sprocket cover
#5 PostAuthor: AL MARSHALL » Fri Oct 18, 2013 7:51 am
z1a has the raised numbers , very easy to polish away
trouble.......seek and ye shall find
www.z-clocks.co.uk
malmojoe
#6 PostAuthor: malmojoe » Fri Oct 18, 2013 8:25 am
Thanks Al, must be a Z1B one I've got. Have changed the title to include Z1A Sprocket cover.
kas750
Re: sprocket cover
#7 PostAuthor: kas750 » Fri Oct 18, 2013 8:42 am
AL MARSHALL wrote:z1a has the raised numbers , very easy to polish away
Yep, one was fitted to my 73 and polished the numbers away.
jimmock
#8 PostAuthor: jimmock » Sat Oct 19, 2013 12:19 pm
My 73 has the correct one, ie no gearshift pattern.
Jimmock. :wnkr
I hate people I don't like !
malmojoe
#9 PostAuthor: malmojoe » Sat Oct 19, 2013 2:32 pm
jimmock wrote:My 73 has the correct one, ie no gearshift pattern.
thank you Jim :nic
