Hope you can help again
Chris
Steven Cooke wrote:Earth wire, on my Z1000A1 the round terminal of the thick wire is to battery negative, the other end is bolted to the back of the battery box earthing to frame, and the smaller wire coming from the round terminal goes to the engine earthing point behind the kickstart shaft. mine doesn't have the other small wire that comes from the bigger terminal, I don't know if this is correct or not it is just how mine is.
