Is this correct Z650
maltatrucker
#1 PostAuthor: maltatrucker » Thu Nov 07, 2013 7:56 pm
Hi all the B1 is nearly done but my mechanic as asked if there is a 2 way oil feed that goes here on this pic of the side of barrels.any help from you guys would help.
Daz
#2 PostAuthor: z1bman » Thu Nov 07, 2013 8:14 pm
YOU SHOULD HAVE ONE OF THESE OIL JETS ON BOTH SIDES OF THE CYLINDER THEY FIT INTO THE OVAL O RINGS TO INCREASE THE OIL FLOW + PREVENT THE O RING FROM COLLAPSING
maltatrucker
#3 PostAuthor: maltatrucker » Thu Nov 07, 2013 8:22 pm
interesting but just been checking up thanks to your pic with the part number i seem to be a bit confused as they are for the 750 and 1980 on z650 my bike did not have them fitted as its a 1977 B1,so what advice all.
Daz
#4 PostAuthor: z1bman » Thu Nov 07, 2013 8:36 pm
YES YOU ARE CORRECT THE 650 B DID NOT HAVE THEM FITTED ONLY THE OVAL 0 RING
Users browsing this forum: Maunders and 88 guests
