fuel lines - crushed pipe
z1apaul
Paul, I have the same thing on my Z900.
The outside line is a bit of a stretch to the union joint on the carbs, so it has quite a bend at the top where it connects to the fuel tap.
It doesn't seem to be causing any problems with fuel starvation and the bend is not bad enough to totally close the tube.
- rickman CRR
