Wiring diagram j
Wiring diagram j
#1 PostAuthor: Al » Mon Nov 25, 2013 7:02 pm
Anyone got a simplified wiring diagram for a J (probably any model really) with just the bare essentials to get it through an MOT and make it run.
No lights, clocks, horn, fuel gauge, ignition, IC ignitor, fuel injection, indicators, clutch or side stand switches.
Only need earths', battery, charging, on / off ignition switch, DYNA coils, tacho and possibly a brake light.
Oil pressure signal and neutral plunger signal will be plugged into existing vacant slots in tacho which are usually indicator left and possibly high beam blue i think.
I could probably figure it out eventually but the last time i tried it cost me a battery and a pair of green coils!!!
tlc
#2 PostAuthor: tlc » Mon Nov 25, 2013 7:16 pm
I've got a wiring diagram but I expect you would already have the same.
#3 PostAuthor: z1bman » Mon Nov 25, 2013 7:33 pm
free manual download here with wiring diagrams
http://hotfile.com/dl/148104458/5c9f72d ... l.pdf.html
#4 PostAuthor: Al » Wed Nov 27, 2013 9:04 pm
Thanks all, i have the diagram and a standard loom on the bike so will unwrap it and copy what i find that i need.
Looked at the diagram long and hard and the more i look the less i understand
:whoa
Users browsing this forum: No registered users and 194 guests
