Stearing column bearings
How do you get the bearing shells out of the steering column top and bottom!! is there a special tool? the z training video makes it look real simple.
Bike now finished what a joy!
get some 25mm round steel bar and wack em out, failing that you can cut em with dremel to make it easier.
I assume you have no intention of putting em back ?
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
- big green bus
I applied heat and knocked them out with a piece of square bar I had knocking about.
If I was to do it again I would invest in the correct tools for removal and installation.
Doesn't anyone rent the tools out or don't the Z1OC have the tools to lend to members?
****** If applying heat, watch you don't burn the paint or melt the powder coating on the headstock ..... ask me how I know
The trick is in the weight of knocking stick you use
and I found from trial and error a 4lb lump hammer and the round bar achieved the required result without any removal of paint
Keith
mistaken.
mistaken.
Have a look at bikers tool box, think you may even get a discount.
http://www.bikerstoolbox.co.uk/acatalog ... inema.html
what a nightmare, the special drift tool i ordered turned up yesterday and it looked perfect. Good quality and looked like it would do the job. I tried it this morning and it felt like it would work then slid straight past the bearing lip both top and bottom!!!!!!!! the guy makes it look so easy on the Kawasaki training video.
Thanks for all your suggestions ill keep trying.
