SWITCH outage indicator
PETER KZ1A
#1 PostAuthor: PETER KZ1A » Fri Dec 27, 2013 11:55 am
Hi All Merry Christmas,
Bike had a bit of a meltdown last week.Cooked alot of the wiring.I have got the new/replacement loom from Z1Enterprises.I have looked around for the outage indicator switch,but hard to source.It lives under the left hand coil, a 3 pin connection.Are they surplus to requirements?Part number is 28019-001.
The insulation broke down on a dyna coil,which bbq'd alot of the loom!Shit happens.We were 900 ks into a 1200k ride.With the help of fellow Z club members we hot wired her and got her to Augusta,then trailered home the next day.
Replaced ignition,wiring loom,reg/rectifier,right handlebar switch,even fried the headlight.
Any info on that outage indicator be appreciated.
Cheers and happy new year
#2 PostAuthor: z1bman » Fri Dec 27, 2013 12:12 pm
you can use the ones from the 650/750/ 500 although different in appearance they have the same colour coded wires & block connector & do the same job . there are a few of the on ebay usa
PAULJAC47
#3 PostAuthor: PAULJAC47 » Fri Dec 27, 2013 4:04 pm
All the outage indicator relay does is to flash when your brake lamp fails and to switch on the mimic on the idiot light,more complex than you may think when you look at building one,if you are not fussed with the flash function just use a relay to switch idiot light or do what most do and leave disconnected.
Cheers Paul J
Charlie
#4 PostAuthor: Charlie » Fri Dec 27, 2013 4:35 pm
#5 PostAuthor: z1bman » Fri Dec 27, 2013 4:45 pm
Charlie wrote:I guess this is the same too ?
http://www.ebay.co.uk/itm/KAWASAKI-KZ40 ... 2330d987c4
yes that will do the same job :) :)
PETER KZ1A
#6 PostAuthor: PETER KZ1A » Sat Dec 28, 2013 4:14 pm
have since managed to salvage original
Users browsing this forum: Bing [Bot] and 122 guests
