Z1000J/R fork tops.
Z1000J/R fork tops.
Anyone got a good solution for J/R fork top/nut thingys. I have two sets of 1000R forks here and both sets have a different solution to the air valve thing on the top that also holds the spring in, and neither of them look very smart. Anyone got a picture of what they should look like, or even better a better solution that looks slightly tricker? Do PMC or someone make an after market one? Also, anyone had a good experience with putting better/new springs in these and what were they?
Chris i have a tube with a single central valve, which joins both valves together but not sure it come under the heading of trick!!
Might be something here if you are looking to replace the fork springs.
http://www.z1ownersclub.co.uk/forum/vie ... hp?t=27150
Users browsing this forum: No registered users and 118 guests
