i'd like to know the difference between a '82' LTD frame and a '82' J1 frame.
there's a cheap ltd frame on ebay, would it be suitable to use on my J1???
i don't mind adding to it, i'm thinking rear sub frame as long as the major stuff is the same, i.e. headstock, engine mounts, swingarm, etc. are the same
ta muchly, in advance. for you're wisdom
differences in frames
welshphill
- Regular Poster
GO HARD OR GO HOME
- mick znone
welshphill
- Regular Poster
I was told once by I believe Steve Bateman,
Z1000 LTD 1981 onwards rake 29 degrees, Z1000 J has rake of 26 degrees, same as earlier zeds.
