Z!-R throttle cables - ammendments/modifications
ACCELERATOR CABLE:longer overall,longer bit of bare cable,small elbow adjuter throttle end. DE-ACCELERATOR CABLE: shorter overall,shorter bit of bare cable,larger elbow adjuster throttle end. PROBLEM: with larger capacity fuel tank fitted,when steering on full right hand lock,deaccelerator cable elbow hits the top of fuel tank causing possible paint chip/dent detrimentally respectively. MODS: still using O/E bars butR/H switch assembly is O/E but cables run on the outside but dont think this is a problem. CURE: Did MR Kawasaki have an alternative deaccelerator cable (if so part No???)to solve this problem or is it a case of DIY a cable to overcome this problem. THANX
Users browsing this forum: No registered users and 93 guests
