leaking fluid
stormin norman
#1 PostAuthor: stormin norman » Mon Aug 21, 2006 12:50 pm
The front master brake cylinder is leaking fluid. It would appear to be comming from where the brake lever is bolted onto the master cylinder.
Now I assume there is a piston that is being commpressed at this point. Can new seals be purchased or do I start looking for a new cylinder?
#2 PostAuthor: Rich » Mon Aug 21, 2006 4:12 pm
You should be able to purchase new seals, but I would strip it and check the bore first as it may be corroded.
Big John
#3 PostAuthor: Big John » Mon Aug 21, 2006 4:42 pm
You can also get a new piston if required.
