would these fit
baz
would these fit
#1 PostAuthor: baz » Sun Jan 26, 2014 9:18 am
#2 PostAuthor: chrisu » Sun Jan 26, 2014 9:25 am
i think you'd need the wheel/spindle etc to go with that given where the spindle fits - i.e. not at the bottom of the forks.
happy to be proved wrong though................
Redbeard
#3 PostAuthor: Redbeard » Sun Jan 26, 2014 10:26 am
If they're the same as the z1000 ltd forks the speedo sensor is electronic so indeed you may need to check the front wheel compatibility. I thought it was just the ltd's with the leading axle, if so they'll likely be longer as well.
zmaxmotorsports
#4 PostAuthor: zmaxmotorsports » Sun Feb 23, 2014 4:57 am
Youd be better off with the older style kz650 forks that look like your 900 forks.
I use the fork tubes from the 650 which are around 3/4" shorter with the 900/1000 lowers,that way the 900/1000 brakes can be retained. :wink:
10-72 (build date)z1/2-74 z1s/2-75 z1s/77 1428 turbo/77 1170/78 1170/74 z1 1385 turbo nitrous project/80 1000ltd 1327 z1 clone.........
That ol kaw was fast on the draw
Outgunned suzukis and outrunned the law
