Carb Question
Carb Question
On the carbs of my 550 project, an american bike, there are two pipes to the tank, one is the flow inlet, the other is a vacuum or pressure pipe for the tank, how exactly does this pipe work, and if I try to start the engine without a tank fitted, does this pipe need to be left open or blocked to help the motor run ? not sure
Users browsing this forum: No registered users and 207 guests
