Headlight
Wayne1960
Headlight
#1 PostAuthor: Wayne1960 » Wed Feb 05, 2014 1:42 pm
guys. just putting my headlight back together and finding it difficult referring back to the components parts list as i never had that many bits.
I have the black shell, a lens and a chrome ring. I have mounted the shell onto the fork brackets with the indicators and all looks good.
I assume the hole in the bottom is for a nut and bolt and earthing point. Where does the black u shaped bracket go?
i assume you have to remove the rim to adjust the lens?
Is there a subject with pics on this?
Bike now finished what a joy!
#2 PostAuthor: z1bman » Wed Feb 05, 2014 4:03 pm
the 8mm bolt hole it the bottom of the shell is for a headlight stay
Wayne1960
#3 PostAuthor: Wayne1960 » Wed Feb 05, 2014 4:56 pm
So what items 9 & 10? I don't have these!
#4 PostAuthor: z1bman » Wed Feb 05, 2014 5:01 pm
9 + 10 are for sealed beam headlights only
Wayne1960
#5 PostAuthor: Wayne1960 » Wed Feb 05, 2014 5:26 pm
Ok thanks don't suppose anyone has any up close pics if the headlight inside and out. That would help.
A1John
#6 PostAuthor: A1John » Wed Feb 05, 2014 5:35 pm
Your headlamp ring will be one piece with a bulb type 7" glass/reflector held in with sprung metal clips.
Wayne1960
#7 PostAuthor: Wayne1960 » Wed Feb 05, 2014 5:38 pm
Yes that's what I've got but I have a black you shaped bracket wich I think fits inside but not sure!
A1John
#8 PostAuthor: A1John » Wed Feb 05, 2014 5:40 pm
A1John
#9 PostAuthor: A1John » Wed Feb 05, 2014 5:44 pm
#10 PostAuthor: z1bman » Wed Feb 05, 2014 5:45 pm
yours is probably similar to this
Wayne1960
#11 PostAuthor: Wayne1960 » Thu Feb 06, 2014 6:43 am
Thanks that's exactly what I have.
scott
Junior Section leader
#12 PostAuthor: scott » Thu Feb 06, 2014 8:00 am
The headlight stay.....does the z1000a2 have one? If so where does it connect to? Does anyone have a picture of the stay fitted?
A1John
#13 PostAuthor: A1John » Thu Feb 06, 2014 8:49 am
scott wrote:The headlight stay.....does the z1000a2 have one? If so where does it connect to? Does anyone have a picture of the stay fitted?
No stay on an A2.
tlc
#14 PostAuthor: tlc » Thu Feb 06, 2014 9:00 am
The stay causes a problem with vibration.
Even without the stay the original bulb 40w45 can blow so quickly that it becomes necessary to take a pack of 10 bulbs with you on even the shortest of journeys.
Use your original for show and and something like an LC lamp for riding with.
Garn 1
#15 PostAuthor: Garn 1 » Thu Feb 06, 2014 9:55 pm
z1bman wrote:9 + 10 are for sealed beam headlights only
Z1bman, You are usually "spot on" with parts & part nos, as you are in the above case. However, I have found that these parts are essential in most semi-sealed beams also.
Regarding the stay [the black "U" shaped piece], as Tic says, it caused problems with vibration and, although there was an improvement in globes, the stay was discontinued in later models.
Adjustment of lamp is done externally, via philips hd screw item 2 on diag.
RegardZ
