Clutch basket
Clutch basket
Me z1000a1 has started to rattle sounds like from clutch / gearbox area the motors been stripped and all bearings are ok but there is play in the clutch basket which none of the main suppliers can get any more , has any one had a bearing rattle from this before ? I've had the bike for 34 years and its never been apart until now
- Ginger Bear
Cheers, I've spoken to ray debben today and he was going to look at the clutch basket to see if it was not to far gone to re spring it . When you find a bearing gone its simple but not finding one gone is a head ache ,I will of course be replacing them all .
- DogsbolloxofZ1B
mark d wrote:Cheers, I've spoken to ray debben today and he was going to look at the clutch basket to see if it was not to far gone to re spring it . When you find a bearing gone its simple but not finding one gone is a head ache ,I will of course be replacing them all .
Mark,
Have you removed the clutch plates and checked that the caged needle bearing and the inner bush are a good fit? If you can detect a lot of movement then it's probably not worth spending money on replacing springs until you've replaced the bearing or sleeve or both.
Mike
Users browsing this forum: Bing [Bot] and 185 guests
