IN the past I have found that inserting the key often releases the barrel, but this one isn't keen to move
Removing key barrel from petrol cap
- RALPHARAMA
I have order a new cap for the Unitrak, but I notice that the new one doesn't come with a lock barrel. I want to move the one from the old one tinto the new one, but there are no clues in the manual (Genuine Workshop of course
Ralph Ferrand
remove the catch from the underside of the cap 4 screws i think? then there is a small metal cover with an offset cam that you can remove with some pliers it just pulls out then you will see the bottom of the lock/ barrel. there is a spring loaded pawl at the bottom that you need to push to release the lock. also make sure you fit the key to aid removal
Users browsing this forum: No registered users and 185 guests
