Z900 Carb vacuum adjustment
Mowjoe
#1 PostAuthor: Mowjoe » Sun Mar 02, 2014 10:45 am
On the 900-A4 26mm carbs the adjustment is on a screw with lock nut under the top cover according to a you tube vid. Do I have to touch the hex screw that has a tab washer securing it? My hayne manual suggests adjustment is on screws between the carbs but I think that is for Z1 28mm carbs??
Any wisdom appreciated!!
:star
Z900-A4 looking like a Z1B!
PAULJAC47
#2 PostAuthor: PAULJAC47 » Sun Mar 02, 2014 11:27 am
Hi on the a4 you are correct its the screw under the top covers,much better than the earlier bikes,just loosen each of the small nuts and use a long slotted driver to adjust,see how the balance is b4 u start,i would check mix as well with a Gunsons b4 u start..Paul J
Mowjoe
#3 PostAuthor: Mowjoe » Sun Mar 02, 2014 11:44 am
PAULJAC47 wrote:Hi on the a4 you are correct its the screw under the top covers,much better than the earlier bikes,just loosen each of the small nuts and use a long slotted driver to adjust,see how the balance is b4 u start,i would check mix as well with a Gunsons b4 u start..Paul J
Thanks, you reassured me, I'm going in!
Fitted the Dyna S yesterday and have checked float heights and colortuned mixtures although still a little rich it seems. I'll check plug colours again after a blat down the by pass (as they say!)
Thanks MJ
Mowjoe
#4 PostAuthor: Mowjoe » Sun Mar 02, 2014 6:12 pm
All done, got all 4 sync'd then the rain came!
Starting nicely and smooth tickover now :D
