I'm trying to dynamically set the dyna s ignition on a z1100r. My strobe gun has an advance degree setting so I can set it as required. Question is....how much advance is recommended.....I've been told 38 degrees ? Do I just set my gun to 38 degree advance then adjust the dyna s until the 'F' Mark lines up on cylinder 1 ?
How much advance on z1100r ?
Cheers...... I was going to use 38 degrees as recommended by the following guru Greg Cope
http://www.aperaceparts.com/cope.html
Users browsing this forum: No registered users and 119 guests
