push/pull
sweptail
push/pull
#1 PostAuthor: sweptail » Thu Mar 13, 2014 12:35 pm
My new throttle cable arrived tday; problem is its a PUSH cable, but was advertised as a PULL. Will it be ok to fit as a pull or are the cables different?
DavidZ1R
#2 PostAuthor: DavidZ1R » Thu Mar 13, 2014 5:13 pm
They are different, its the chrome elbows, one is smaller than the other so you can screw them in without clashing.
sweptail
#3 PostAuthor: sweptail » Thu Mar 13, 2014 5:41 pm
Ta David.... But will the bike respond ok with a push cable doing the pulling?
garyd
#4 PostAuthor: garyd » Thu Mar 13, 2014 6:17 pm
No, it will go backwards!!!! :twisted: :wink:
IUt will do the job O.K.....just won't fit exactly as it should
samspoons
#5 PostAuthor: samspoons » Thu Mar 13, 2014 7:46 pm
Back in the day I used to use the push cable as a spare if the pull one snapped.
I never noticed any adverse effects, but then again im not fussy. :wink:
sweptail
#6 PostAuthor: sweptail » Thu Mar 13, 2014 10:44 pm
Ta lads..... ill give it a go. I wish they wud send wot they advertised... :twisted:
Big Fluff
#7 PostAuthor: Big Fluff » Fri Mar 14, 2014 10:33 am
sweptail wrote:Ta lads..... ill give it a go. I wish they wud send wot they advertised... :twisted:
Only a guess, but if you got it from Wemoto, let them know and they'll send you the correct one out immediately.
Personally I use Wemoto for as much as I can because they never take money for something they haven't got stock of, they are extremely quick at delivering, everything priced sensibly and they have a huge stock of parts. Plus they are all into bikes themselves..... I can't praise them highly enough! :up
Users browsing this forum: No registered users and 134 guests
