Needed urgently a 31mm exhaust valve
Padders
#1 PostAuthor: Padders » Sun Mar 30, 2014 6:39 pm
Hi I have a bent exhaust valve on my Z1 head that needs replacing but the valves are oversize 31mm. Martin has been checking and H exhaust valves are 31mm if anyone has a decent one for sale and could check the size please. Also APE and Manley do 31mm ones if any one has one for sale. This is the largest you can go on the standard seats and the bike is VOR until I can source one.
Does anyone know if any others will fit to help with the search.
PUM 13
hillbilly
#2 PostAuthor: hillbilly » Sun Mar 30, 2014 8:17 pm
the valves from a diesel 4.2 Toyota lndcruiser are same size,(not sure which ones)inlet or exhaust.just a bit longer on stems,can be machined down to suit.last I heard they were £8 each.
Padders
#3 PostAuthor: Padders » Sun Mar 30, 2014 8:30 pm
Cheers Brent would prefer ones that require no work if I can find one or a set.
PUM 13
Big Fluff
#4 PostAuthor: Big Fluff » Mon Mar 31, 2014 11:54 am
Ian.
Please read latest reply in the 'Wanted' section.
Fingers crossed.
Regards, Will
Padders
#5 PostAuthor: Padders » Mon Mar 31, 2014 11:58 am
All my fingers are crossed Will thanks :D
PUM 13
Padders
#6 PostAuthor: Padders » Fri Apr 04, 2014 5:59 pm
All sorted now thanks, Ray at Debbens sorted me out with an APE stainless one. It appears the ones fitted are Manley. Bad news is the valve seats need recutting so a big box will be winging its way to Debbens.
Thanks for all those that pm'd,called and text'd me with offers of advice parts and help appreciated you taking time out guys to help.
PUM 13
Users browsing this forum: No registered users and 200 guests
