Dry battery ?
snotie1965
Dry battery ?
#1 PostAuthor: snotie1965 » Sat Apr 05, 2014 12:59 pm
I put a new Exide battery on my gpz11 ut about 4 / 5 months ago and i had to bump start the bike yesterday because it was flat , so when i took the battery out to charge and check it ,it was completely dry !! ?
what would cause this ?
I do use a trickle mate 500 charger, when left for any length of time 2 / 3 days or more ?
Also is it worth me trying to get it back to life with new distilled water and a good long slow charge ?
garyd
#2 PostAuthor: garyd » Sat Apr 05, 2014 1:02 pm
The battery has had it....you need an eletorlyte to make it work again....and in all probability it's got hot and warped the pates.
#3 PostAuthor: z1bman » Sat Apr 05, 2014 1:05 pm
check the charging voltage. most likely over charging & boiling the battery dry
snotie1965
#4 PostAuthor: snotie1965 » Sat Apr 05, 2014 1:11 pm
garyd wrote:The battery has had it....you need an eletorlyte to make it work again....and in all probability it's got hot and warped the pates.
What is "eletorlyte" ? it might save me another 50 quid for a new battery ?
#5 PostAuthor: z1bman » Sat Apr 05, 2014 1:18 pm
snotie1965
#6 PostAuthor: snotie1965 » Sat Apr 05, 2014 1:28 pm
z1bman wrote:eletorlyte = SULFURIC ACID
http://www.ebay.co.uk/itm/Special-Offer ... 1274100821
Cheers , i never knew it was called "electrolyte" ?
PAULJAC47
#7 PostAuthor: PAULJAC47 » Sat Apr 05, 2014 1:49 pm
This shows a bit more detail
http://inventors.about.com/od/bstartinv ... -Works.htm
You can just try distilled water in your dry battery,but as stated the plates are probably warped through over charging by your battery charger giving out too much voltage or more likely your voltage regulator is duff on the bike,you should get around 14.5 volts dc at 3k revs across the battery if all is ok,
Cheers PaulJ
snotie1965
#8 PostAuthor: snotie1965 » Sat Apr 05, 2014 2:33 pm
PAULJAC47 wrote:This shows a bit more detail
Cheers PaulJ
Cheers ,i had a quick browse through the link about batteries .
What i have done is ordered a cheap battery for now 28 quid delivered ,and also i have my old original battery on the bike now , the new one that i took off will be filled with new acid and recharged ? it has got to be worth a try ?
So in the end i will have a "shed load" of batteries and still be bump starting it :roll: and also will check ou-put from terminals ?,but the tacho volt gauge reads 13-14 volts ??
#9 PostAuthor: Pigford » Sat Apr 05, 2014 3:54 pm
When they run dry - its only the WATER element that evaporates - the acid will still be in it - so just ad dostilled water only to top it up :!:
Probably fooked anyhow :??
snotie1965
#10 PostAuthor: snotie1965 » Sat Apr 05, 2014 3:56 pm
Pigford wrote:When they run dry - its only the WATER element that evaporates - the acid will still be in it - so just ad dostilled water only to top it up :!:
I re-filled it with DOstilled water ! and see what happens ? i am learning loads of new words :lol: :lol:
#11 PostAuthor: Pigford » Sat Apr 05, 2014 4:00 pm
Yeah - thats the cheap version of distilled water :P
Charlie
#12 PostAuthor: Charlie » Sat Apr 05, 2014 4:16 pm
This is a normal lead/acid battery you are talking about - not one of maintenance free YTX/GTX/CTX types ?
Those are meant to appear dry - all the eloctrolyte on those is absorbed into the glass matting surrounding the plates. For ferks sake - never open or add water/acid to those after the initial fill ......
snotie1965
#13 PostAuthor: snotie1965 » Sat Apr 05, 2014 5:10 pm
Charlie wrote:This is a normal lead/acid battery you are talking about - not one of maintenance free YTX/GTX/CTX types ?
Yes they are normal type batteries , with tops that come out and a high and low mark for topping up .
I did have a look at the new type lithion dry batteries but they are £200 + and are still not fully tested ? (not good in the cold) apparently ?
#14 PostAuthor: Pigford » Sat Apr 05, 2014 6:20 pm
I got a lithium ion battery for just over £100 :wink:
StevieT
#15 PostAuthor: StevieT » Sat Apr 05, 2014 6:46 pm
I can highly recommend the Motobatt range. Prices from about £50 on Bitzforbikes
Z1A
Users browsing this forum: No registered users and 219 guests
